Power Vinyl Strippers - Flooring - DIY Chatroom Home Improvement Forum
Old 04-02-2008, 09:04 PM   #1
Homewrecker
B Parker's Avatar
Power vinyl strippers
hello again group,
trying to remove vinyl glued to concrete with the putty knife and hammer method....not going well. thinking of renting an electric vinyl stripper from HD.
Do these things really work well for the application I'm working with?
Any input would be appreciated.
B Parker is offline   Reply With Quote
Old 04-02-2008, 09:41 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
as long as it is a good machine (as in heavy heavy and mean)
the riders are really cool.
Old 04-03-2008, 07:55 AM   #3
Homewrecker
B Parker's Avatar
Just from talking with the rental dept over the phone, I'm thinking it's like a spud bar with a blade that operates like a mini jackhammer? Would this be a correct assesment?
Old 04-03-2008, 03:38 PM   #4
nap
You talking to me?
nap's Avatar
these are a couple different variations of a power tile scraper.
I think this one os more what you are thinking of.
Harder to use because you have to hold it up.
Old 04-03-2008, 04:26 PM   #5
Homewrecker
B Parker's Avatar
I believe you're right, thanks for the pics, I may try to find a local place that has the one in the google link. It looks small enough to maneuver, and looks like it would be less work involved.
Old 04-08-2008, 03:52 PM   #6
Homewrecker
B Parker's Avatar
Well, I did it, used the handheld one like the one you pictured. I really wish that it had the handle in the middle of the shaft like that one!
It was not the "Hot knife through butter" experience that I was hoping for!
Man, I think I lost of couple of fillings to this job.(very shakey....)
It beat the heck out of doing it by hand though. I was left with quite a bit of the backing but it comes up fairly easily with a 9" razor scraper.
Thanks to all for the input.
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
