Old 05-27-2009, 12:49 AM   #1
Post Tension Concrete Slab
One of the post tensin cables in my homes concrete floor broke and came through the foundation wall with no interiour damage. Does it need to be repaired or is it safe to allow it stay as is?
jeff gloeb is offline   Reply With Quote
Old 05-27-2009, 11:11 AM   #2
we'd hope you already know the answer,,, if the engineer'd thought it unnecessary, who do it ? ? ? you're betting against slab warp now,,, if 1's broken, the prudent owner'd have it repair'd post haste + have the others ck'd by a competent technician,,, this IS extremely special work ! ! !
yesitsconcrete is offline   Reply With Quote
Re-using post holes in concrete philS Building & Construction 8 05-04-2009 09:15 AM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 05:11 PM
lifting up concrete slab ctudan Building & Construction 1 10-28-2008 03:44 PM
Bad Concrete in Fence Post Holes - Advice? bcrenshaw Building & Construction 2 08-24-2008 12:21 PM
Bathroom subfloor on concrete slab question Mikedks Flooring 2 02-20-2008 08:28 PM
