Post And Beam Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 01:50 PM   #1
Post and Beam installation
Hey guys. My name is Josh. New here so go easy on me. I live in a 1000 sq ft (40x25) home in a rural area. I bought this home not knowing that it was built from remnants of an old school house back in the early 50's, when code wasn't enforced. The house sits on only one 40' girder with 4 brick columns. The floor sags on one side of the girder with noisy creeking on both sides. I also noticed a few stress cracks above doorways so I decided to do a post and beam installation with 6x6's and 2x10's on both sides of the girder to increase the structural integrity of this old house. I dug the first post hole and found ground water at 1'. What should I do about pouring concrete into the post holes that have ground water? Or if there is a better way of doing this let me know I wouldn't mind to start over. Any help would appreciated greatly. Thanks in advance.
Josh
mrbojanglezzzz is offline   Reply With Quote
Old 02-24-2011, 01:54 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 56
You would have better luck in the construction area of the forum. This part is for floorcovering.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 02-24-2011, 02:05 PM   #3
Hey thanks!
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Modified post and beam framing question? diywengr Building & Construction 7 08-11-2010 09:18 AM
New deck - Gap between beam and post due to shrinkage? DaveNJ Building & Construction 3 07-06-2010 08:23 AM
Deck Beam connection to Post? CNJHomeowner Building & Construction 7 08-08-2008 07:14 AM
