Porch Flooring Recommendation - Flooring - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 11:31 AM   #1
I'm in the design phase for building a new porch. I've been reading through these forums trying to find an idea which will work for me but haven't quite found a thread which will work.
I live in Seattle, WA. My existing front porch is over my basement and when we get a good rain here, water will leak through the existing porch into my basement. I'd like to come up with a flooring option that will minimize or eliminate the water coming into the basement.
I will frame in half the existing front porch and move my entryway there. That solves half the problem.
I am also going to build out the front porch 4' and build a side porch. My lot has a slope to it. Where the front porch stairs will be, the porch will be about 3 feet off the ground. Where the side porch stairs will be, I will have to dig out ground to build the porch.
I was originally going to lay plywood down, redguard, then tile the porch. However I'm starting to read that might not be a good idea.
What would your suggestions be for this? I thought about doing concrete for the side porch with lightweight concrete for the front porch. One issue I will have is there is two tree roots where I plan on building the side porch. I've indicated them in the drawing. Could I still do concrete there but instead of pouring directly on the ground, use concrete pier blocks, raise the deck up a foot and then pour?
Any advice would be appreciated!
RyanS. is offline   Reply With Quote
concrete floor , deck , porch , tile
Adding to Concrete Porch + Steps? 99altrade Building & Construction 8 08-01-2011 12:14 PM
Deck flooring recommendation needed tinkertoo Flooring 8 05-07-2011 07:27 PM
porch flooring at top of steps shtoink Building & Construction 1 03-05-2010 12:07 PM
Open two story porch flooring blane11 Flooring 1 09-28-2009 06:26 PM
New tongue-and-groove porch flooring is buckling Wendyabes Flooring 4 03-30-2009 01:22 PM
