Old 01-03-2009, 05:21 PM   #1
porcelain tile questions
Hello,
I have decided to install porcelain tile in my bathroom.
I wish to take a little extra time in the design pattern of the tiles themselves, to try to make something eye catching
I have bought the 12" x 12" tiles for the floor, but I was not able to locate the 6" x 6" equivalent tile for the walls.
THE QUESTION IS
Is it possible to cut those tiles with a wet tile saw to make 4 6x6 tiles from one 12x12", and use them on the wall?
The porcelain tile I am using has a pre-finished surface on it.
And, it is possible to file down the edges of newly cut 6x6's to make the beveled edge?
any thoughts or alternatives to this solution??
-gramps
gramps416 is offline   Reply With Quote
Old 01-03-2009, 06:58 PM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
I would recommend against cutting the tiles down to size. I don't think you'd be able to recreate the factory edge over that many cuts.
What about a similar tile in the size you want, perhaps in a complimentary color?
Angus
angus242 is offline   Reply With Quote
Old 01-03-2009, 08:45 PM   #3
I think i will try that. You are right about the quality of the cuts.
thanks
-g416
Old 01-04-2009, 07:14 AM   #4
Angus has a good point. All the porcelain that I've worked with I can cut with a diamond blade but not file. It is tougher than hardened steel and will burn out carbide bits, so if you need to drill for any fixtures get a bit rated for glass. You may be able to cut a bevel with a diamond saw or wet saw but you'll probably grow new teeth faster than filing a bevel to match the factory detailing.
Chemist1961 is offline   Reply With Quote
Old 01-04-2009, 08:54 AM   #5
Remodeling Contractor
The bevel can be made quickly with a cone diamond shaping stone from a stone retailer. But as mentioned...never will look like it should. Color at the edges (glazing) is missing.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 10:01 AM
porcelain tile over electric radiant heat aak3 Flooring 7 01-30-2008 09:33 AM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 10:35 PM
