-   -   Porcelain tile pros/cons? (http://www.diychatroom.com/f5/porcelain-tile-pros-cons-28307/)
4carrs 03-24-2005 12:44 PM
I am planning to renovate our basement into a home office. I was planning to use porcelain floor tile. Are there any advantages/disadvantages to using porcelain tile versus ceramic tile? The basement is dry and I do not anticipate any future problems with water or moisture.
4carrs
Oray 11-03-2006 09:15 PM
Porcelan is made of finer clay and fired at a higher temp and will hold up better to moisture. Good luck and Happy trails.
MattCoops 01-10-2007 07:48 PM
in basements I like to suggest 2 thin coats of RedGuard anit-crack / waterproof membrane
you can get it at home depot
alfy 02-14-2007 03:59 PM
Porcelain is much harder to cut and drill than ceramic and certain cuts can be a nightmare.
