Porcelain Tile Problem! - Flooring - DIY Chatroom Home Improvement Forum
Old 09-07-2010, 09:24 PM   #1
Unhappy
porcelain tile problem!
We pulled up the laminite flooring and tried to scrape off the glue the best we could. Then we laid the porcelain tile that was 16" x 16" and the premixed adhesive never seems to dry after 1 month. Then we grouted it and of couse it cracked, but now I'm at the point that I don't know what to do. I don't know if I should re-grout, replace the tiles that still aren't sticking or re-do the whole floor. My whole kitchen is a mess! Please help! Can the existing tile be saved?
1017txgrl is offline   Reply With Quote
Old 09-07-2010, 09:53 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
You should have never used the pre-mixed jun........ ah ah ..stuff. How did that happen?
You must removed everything including the mastic and start over. You can start removing the tiles right now, but don't start over until you've told us the entire story and exactly what you've got starting with the substrate. It'll take several posts to get you on the right track.
Jaz
Tags
adhesives , flooring problems , porcelain tile , tile problem
Porcelain click and lock floor tile TRACKER Flooring 16 07-17-2012 06:59 AM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 07:11 PM
porcelain tile questions gramps416 Flooring 4 01-04-2009 07:54 AM
Installing porcelain tile on a sloping floor Wanttodoitright Flooring 11 03-20-2008 01:37 PM
8 x 17 Porcelain Wall Tile steve65 Flooring 4 03-19-2008 10:26 PM
