Old 09-18-2009, 05:25 PM   #1
Default Porcelain Tile Porch
I am in construction of a new home. Farm style with wrap around porch. Porch is about 1600sqft total. I am trying to decide what type of flooring. Wife hates the 1x6 pine deck boards. I am afraid that tongue and groove porch flooring will fail quickly and need much maintenance. Looked at IPE but way expensive. Simulated wood is also very expensive. So I began looking at porcelain. It will also be expensive compared to deck boards but cheaper than other options. Here is what I have. Maximum span on porch is 8ft. All joists are on 16" center and are 2x10's. My plan would be to lay down 3/4 advantech and then use ditra. Will my tile fail and pop or crack in no time or will this be a maintenance free porch. If I do go this route what do people put at the joint of the brick house and the tile porch for trim. No water would get to that point so not sure I need flashing but something to cover the joint.
Thanks,
jb
jbtn9 is offline   Reply With Quote
Old 09-19-2009, 12:11 AM   #2
Default Location
Forgot to post that I am located in Tennessee. We get some cold weather but not extreme. Definitely a possibility for freezing though. Any help with my question is greatly appreciated.
Old 09-20-2009, 04:56 PM   #3
Licensed Contractor
Exterior tile in climates prone to freezing has historically been taboo, unless this is an enclosed porch. You won't find much, if any, here in the northeast. Water migrates under the tile and when it freezes, it expands and - pop - there goes your tile job.
However, a few years back I was looking into tiling a couples front porch, and Ditra's Schluter said that, using their products and following their instructions, you should not have a problem. I didn't get the porch job, so I can't say if they are right.
Personally, I don't see how tiling could be cheaper than any of your other options. Look at Tendura, a composite T&G porch decking.
Renovator,LLC is offline   Reply With Quote
Old 09-20-2009, 10:49 PM   #4
I have a wrap around.... it's 1x6 wood and a PITA to maintain since we made the mistake of staining it dark brown (previous clear coat).....now everything little imperfection/dirt you can see...
i would seriously look into how long tile will last outdoors before doing so.. if anything settles just a bit it seems the cracks would start ..........the big ol porch is not what it's made out to be.....
Ineedhelp2009 is offline   Reply With Quote
Old 09-21-2009, 02:13 PM   #5
Default still undecided
I looked at tendura and other brands of composite flooring and have seen a lot of mixed reviews. Many people tend to hate it and seems there are several lawsuits against some the major companies.
Composite (t&g): $16000
Ipe(t&g): $16000
Porcelain: $8000
Pine (kdat t&g): $3000
All of these numbers are with me doing the labor.
Pine looks the best cost wise but if I have to replace in 10 years or have to stain every 3rd year then it is not the best choice.
Anyone got any comments on the composite. Sounds like it can not receive direct sunlight and my porch would for some of the day.
Tags
porcelain tile porch
More On This Topic
In our home renovation, we built a new entryway. What we did was this area that you see here connects with a long rock porch that goes around our house. This area, the full length of our house, was a cement porch. It was just bare cement and it went down... Read More »
Where To Play Jacks
Where To Play Jacks by Expert Village
Hi, I'm Jamie Peterson. I'm here on behalf of Expert Village and I'm here to teach you how to play jacks. Jacks is a really fun game and it can be kind of tricky. But once you get the hang of it it's pretty easy. The first thing you need to do is play... Read More »
Okay now we’re going to talk a little bit about floorings. One flooring a lot us have in our homes that we don’t even know we have and we can utilize is a concrete slab. A concrete slab, you can strip your wall to wall carpeting and take the... Read More »
Porcelain floor tiles are harder than ceramic tiles and durable beyond compare. The problem is that they're also quite hard to drill through and cut. To drill through porcelain floor tiles, you have to use a diamond drill bit. Read More »
Creating an inviting outdoor space by building a patio is a great idea, but can become a great headache if not well thought out. Put together a budget and develop your project plans before getting started and your wallet and home will thank you for it. Read More »
Tile on Front Porch PearlWhiteGT Flooring 8 04-24-2009 03:43 PM
porcelain tile questions gramps416 Flooring 4 01-04-2009 09:54 AM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 11:01 AM
8 x 17 Porcelain Wall Tile steve65 Flooring 4 03-20-2008 12:26 AM
porcelain tile over electric radiant heat aak3 Flooring 7 01-30-2008 10:33 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
