Porcelain Tile Over Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 08-10-2008, 10:00 PM   #1
FarmGirl
Porcelain Tile over Linoleum
Help! Dying to tile but have some questions:
Situation:
Concrete slab, no visible movements or cracks with vinyl nonpadded linoleum over the top. No curling edges, nothing is coming up. Been installed for about 20 years. Tried to pull a corner and it is securely fastened, doesn't even offer to come up.
Can I tile right over the top?
Thanks. H and D
hsmithfarms is offline   Reply With Quote
Old 08-11-2008, 07:52 AM   #2
ccarlisle's Avatar
You could; I wouldn't...even nonpadded linoleum deosn't offer the resiliency that I would like under porcelain tiles. Some may live with it, I don't think I could...but then, hey, that's just me!
You could put something over it to provide a solid backing for the tiles, but do you have that amount of room say for an extra 3/4" on top?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 08-11-2008, 09:38 AM   #3
FarmGirl
I do have about 1" to work with if I were to add a layer of cement board down but everything I have read says not to put cement board over cement....??
Thanks.
Old 08-11-2008, 01:55 PM   #4
Edie
EdinDesign's Avatar
No... not cement board... what you want is an anti-facture membrane that's intended for use over cement, even if you're putting it on the lino that's on the cement. Kerdi has a great product, but it'll add height to the floor. I've used this great product (can't remember the name - sorry!) that's essentially an interwoven felt pad - it's sticky on one side, you roll an adhesive (a special kind for this underlay) on the floor... lay the pad down and it won't move. Great stuff. Ask a tile supplier... they'll know what you should use.
EdinDesign is offline   Reply With Quote
Old 08-11-2008, 04:53 PM   #5
ccarlisle's Avatar
That's DITRA from Schluter.com.
Old 08-11-2008, 06:58 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
EasyMat.
Old 08-11-2008, 07:17 PM   #7
ccarlisle's Avatar
Bud's right...
I can't read. duh.
Old 08-12-2008, 01:50 AM   #8
Edie
EdinDesign's Avatar
That's right Thanks Bud!
Dittra is the Kerdi I was referring to. Thanks for that, CCarlisle
Old 08-12-2008, 02:48 AM   #9
K&B Remodeler/Tile Guy
angus242's Avatar
Farmgirl,
Just because something technically can be done doesn't mean it should be (as has already been mentioned).
I'm doing a small tile installation in a town house this week. The customer's neighbor stopped by to see how things were going. He started laughing as he looked around and saw what I was doing. "Why are you laughing?" I asked. He (the neighbor) said he just had the same kind of tile work done in his unit and went with the cheapest quote. His installer put tile over linoleum. His installer never bothered to remove the baseboards and shoe molding. His installer never mentioned a crack isolation membrane. His installer didn't bother to use protective film over the carpet while working. His installer's installation failed in less than a year.
Taking shortcuts doesn't always help. A properly done tile installation will last a long, long time. Does skipping a few days worth of work seem worth it in the long run?
Angus
My Albums
angus242 is offline   Reply With Quote
Old 08-12-2008, 09:06 AM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Say What?
KERDI DOES NOT ADD any discernible height to a floor.
DITRA and KERDI are two entirely different products. That statement must be a typo.
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 10:01 AM
8 x 17 Porcelain Wall Tile steve65 Flooring 4 03-19-2008 11:26 PM
Porcelain tile over linoleum. STEPHENWANGEL Remodeling 12 08-17-2007 10:46 AM
Tile over old linoleum? SeattleDuck Flooring 1 09-22-2006 03:58 PM
