Porcelain Tile Over Black Emulsion - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2012, 07:00 PM   #1
Rewards Points: 636
porcelain tile over black emulsion
original vct was installed in the 1980's on at grade concrete so i assume it is emulsion
so my questions are as follows
1 do i need to remove the emulsion
2 if so what is best to use to remove using practical diy tools "i know a carbide tooth scraper on a buffer with vacuum would be best but not available"
3 would covering the emulsion with a crack membrane paint work like link instead
http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
4 what type of thin set to use
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-12-2012, 07:56 PM   #2
DIY staff
Rewards Points: 7,174
Do not use any solvents--it will be a bond breaker---
Scrape off what you can using a razor scraper and you can tile right over it--
Use an unmodified thinset mixed with liquid latex--Kerabond and Keralastic by Mepei is a good example.
If leveling is required use a self leveling compound rated for cutback--I use Jifset and Linewebers liquid.
Some modified thinsets are rated for cutback also---check the manufacturers technical details to know for sure. (do not seek advice from a big box store---call the manufacturer)---Mike---
jaydevries (03-12-2012)
Old 03-12-2012, 08:36 PM   #3
Rewards Points: 636
ok how about a floor grinder like this one in link
http://www.toolfetch.com/surface-grinders-158780.shtml
i found out a rental place has one
Old 03-12-2012, 08:40 PM   #4
DIY staff
Don't mess with it---bury it---you don't need to use a power tool at all--simply scrape off what you can--call that good and tile over it.
It's an approved method that works---you don't want to get that cut back stirred up with a grinder.
24x24 polished porcelain tile counter sbrunke Flooring 8 11-18-2012 09:12 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Porcelain tile over linoleum floor Jac121 Flooring 11 01-06-2012 07:32 AM
No bull nose available for porcelain tile I chose acerunner Tiling, ceramics, marble 13 06-10-2011 11:03 PM
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 07:11 PM
