Porcelain Tile On An Outdoor Sundeck... - Flooring - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 10:54 AM   #1
Porcelain tile on an outdoor sundeck...
I have porcelain tile installed on an outdoor sundeck here in South Florida...I have been having some water intrusion issues and want to seal the floor.....the grout was initailly waterproofed with penetrating sealer and mortar mix...but I dont think this is enough for an outdoor application such as this....the floor is only about six months old and some of the grout is showing signs of shrinkage due to being in the direct sun all day...I need a good sealer that will withstand the elements......thanx in advance...Rick
Rick227 is offline   Reply With Quote
Old 05-11-2010, 06:05 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Grout sealers are not waterproofers.
XXX
Old 05-11-2010, 11:06 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 346
Rick,
As Bud said sealers do not waterproof anything. Also grout is NOT a waterproofer, it's a joint filler that is not adversely affected by water.
It's likely your problems were caused by some installation method deficiencies. I would need to know how everything was done and with what specific products. Also need to know the conditions of the substrate and the exposure orientation of the sundeck.
You can start with the slab and work up from there.
Jaz
Old 05-12-2010, 05:49 AM   #4
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
Grout doesn't just shrink away due to sunlight either. Sounds more like it wasn't filled all the way and the grout is slumping into the joint as the moisture comes out of it.
poppameth is offline   Reply With Quote
Old 05-12-2010, 10:32 AM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What are "water intrusion issues"? I don't know what that means.
As mentioned...the sealer won't waterproof the grout. What is the meaning of the "mortar mix" comment in that statement?
What type and brand of grout was used? Be specific. Standard grouts won't shrink from the sun beyond some minimal shrinkage that may occur during the first few hours immediately following the initial installation.
You should first understand the function of the products you are trying to use. Do you have a picture to show us?
XXX
How to anchor toilet flange to porcelain tile? bobmg Plumbing 32 08-19-2013 09:32 PM
Porcelain Tile with sharp edges crackpot Flooring 1 03-31-2010 09:51 PM
tile saw advice for 24" porcelain tiles diy'er on LI Tiling, ceramics, marble 12 10-11-2009 03:34 PM
porcelain tile questions gramps416 Flooring 4 01-04-2009 07:54 AM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 09:01 AM
