Originally Posted by Burat
My builder wants to charge $3/sq ft EXTRA to lay down porcelain tile, versus no extra charge for ceramic - is this reasonable (I am building a house in NJ).
Maybe I should just stick to ceramic tile (this is for the kitchen); does anyone think there is a difference bet the porcelain and ceramic tiles in regards to puppy attacks?
Is that just extra labor charge for installation or covering the tile upgrade also. The porcelain product is more expensive than ceramic, and his tile setter may get a little more for installation as there is often breakage (thus recuts) when porcelain is cut around corners or fixtures. If it covers both, it may be a little high, but I would not call it unreasonable. I personally do not see this recent fascination with porcelain for residential use. It is a comercial product that has some how come into residential vogue. If you are getting a quality ceramic, it will be more than sufficient for a residence, but do avoid the bottom end stuff.
JUST SAW YOUR FOLLOWUP THAT IT IS PURE LABOR, NOW I WOULD CALL THAT OUTRAGEOUS.
