Porcelain Tile Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 11:43 AM   #1
porcelain tile installation
How important is it to clean back of tile as well as floor before installation? Should all dust be removed?
clarktmb is offline   Reply With Quote
Old 07-06-2011, 12:48 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Very!
Well of course!
XXX
Old 07-06-2011, 01:55 PM   #3
Thanks for the reply. I agree also, but was being accused of being too picky by relatives (I was vacuuming the backs of tiles as well as the floor). They said any dust or dirt would be absorbed by the mortar and wouldn't affect adhesion. Thanks again.
Old 07-06-2011, 04:26 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
They have no idea what they are talking about.
Wrong!
Here's the deal. Fired clay tile surfaces are contaminated with what is known as "kiln release". It is a powdery silky product not unlike talcum powder that is used in the manufacturing process. The tiles in most cases are cleaned but only with compressed air. This leaves a powdery residue that can in fact repel any tile adhesive. I have seen this in re-dos many many many times over the years when repairing a tile installation failure due to improper timing of tile placement and allowing kiln release to remain on the tiles.
True the adhesive will absorb some dust but not all.
Vacuuming the tiles isn't enough and isn't the industry recommendation either. The use of a wet sponge to clean the tiles and the substrate is the recommendation. In addition, you should always clean any cementitious substrate with a wet sponge just ahead of spreading thinset mortar.
Then there is the matter of common-sense. What would common sense say to do?
XXX
Old 07-06-2011, 06:12 PM   #5
Thank you very much for the information. Much appreciated. Now realize I should have asked this question before installation. Maybe I'll get lucky with this install.
Thanks again.
Granite Tile Discoloration during installation russ2008 Flooring 16 03-27-2013 01:01 AM
Framing a wall over porcelain tile Gentleman Farme Drywall & Plaster 2 03-20-2011 02:10 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Best tool to drill holes in Porcelain tile theedudenator Tiling, ceramics, marble 6 12-09-2009 06:44 PM
tile saw advice for 24" porcelain tiles diy'er on LI Tiling, ceramics, marble 12 10-11-2009 03:34 PM
