Old 06-28-2011, 05:13 PM   #1
Porcelain Tile Floor
I found a polished porcelain floor tile for my kitchen/dining room. Now comparing companies for the best price...in doing so I learned that some polished porcelain tiles have a thin top layer of glass. Does anyone know if this is the way to go....should I only consider the glass layered, or is polished good enouph?
JeanetteB is offline   Reply With Quote
Old 06-28-2011, 06:04 PM   #2
Tileguy
Bud Cline's Avatar
All "glazed" ceramic tiles have a top-coat of glass-like covering.
Porcelain tiles come both glazed and unglazed and are in fact also ceramic tile but of a slightly different recipe.
Polished porcelain usually doesn't have a top-coat because it is hard enough and dense enough to be able to polish the surface without the glazing.
Stay with a porcelain tile, you won't go wrong there.
Old 06-28-2011, 07:29 PM   #3
if its shiny and really smooth it'll be slicker' n' snot when it gets wet.
Tags
floor, porcelain tile, tile floor, tile floors
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
replace wall tile without damaging floor tile bruswain Flooring 3 05-21-2011 07:29 AM
Basement Floor Variance Allowance When Installing Ceramic Tile june Introductions 0 10-26-2010 11:09 AM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
