Porcelain Tile Around Toliet Not Level - Flooring - DIY Chatroom Home Improvement Forum
Old 07-07-2013, 10:05 PM   #1
Rewards Points: 14
porcelain tile around toliet not level
- completely gutted our bathroom
- everything new
- subfloor 1 1/4 inch CDX plywood
- 1/4 inch durock on top of vesabond mortar and screwed correctly
- redgard (leftover from shower / tub)
- 12 inch porcelain tiles set using flexbond mortar
- lines / gaps perfect and everything level
- used a short and long level the entire job
- vertical, horizontal, and diagonal
- tiles have been setting for two days
- installed new closet flange and it was sitting pretty
- proceeded to install toilet.
Um... oh-oh... Two tiles in front of the toilet dropped almost but not quite 1/8 of an inch. Just enough to make the toilet rock. I have heard about using plastic shims, however, I think the best thing to do would be to pull up the two problem tiles and set new ones in place. I mean, I've come this far. I would hate to do all that work and leave it like that.
The tiles didn't sag from anything other than me doing it.
The question: What would be the best approach to removing the tiles without destroying the durock underneath??
any suggestions would be deeply appreciated.
worthspending is offline   Reply With Quote
Old 07-08-2013, 05:17 AM   #2
DIY staff
Rewards Points: 7,174
There is no way to know how the Durroc will survive---Just take your chances--remove the grout--smack and crack the tile and remove it---repair the Durroc if if is damaged---
Old 08-20-2013, 10:27 PM   #3
Unless the tile looks real bad aesthetically ...shim the toilet and grout the gap with a flexable color matched grout. Will hold up just fine and u will probably never notice.
Godspede619 is offline   Reply With Quote
Porcelain tile over particle board over concrete slab? roughtrader Flooring 9 04-16-2012 11:24 AM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 10:43 AM
porcelain tile questions gramps416 Flooring 4 01-04-2009 07:54 AM
porcelain versus ceramic tile pandora Flooring 55 11-24-2008 09:01 AM
8 x 17 Porcelain Wall Tile steve65 Flooring 4 03-19-2008 10:26 PM
