Pool Table On Floating Hardwood Q......... - Flooring - DIY Chatroom Home Improvement Forum
Old 07-28-2008, 07:40 AM   #1
Rewards Points: 324
Pool Table on Floating Hardwood Q.........
Nearing the end point of finishing the basement. A pool table already sits on the concrete floor but I am in the process of putting down the engineered hardwood floating floor(glue together). I need to do half of the floor, then move the pool table onto the new floating floor, then complete the other half. How long should I wait after doing the first half before I transfer the pool table?
thanks
tigerbalm2424 is offline   Reply With Quote
Old 07-28-2008, 07:46 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
How long does the manufacture say you can walk on it when finished???
is it a slate table??
Old 07-28-2008, 07:50 AM   #3
Rewards Points: 324
They dont
I got the floor direct from the China factory and the guy that sold it to me didnt give me any instructions. He is a distributor but has never sold this product. It was for a model floor that never was installed.
Yes, it is 1 inch slate.
Old 07-28-2008, 08:53 AM   #4
buletbob's Avatar
I would glue the floor up to the pool table and wait the 24hrs. and then move the table on the new floor and finish with the flooring. just put some plywood pads under the legs so to spread the weight. BOB
Old 07-28-2008, 09:09 AM   #5
Rewards Points: 324
Sounds good. I will do some cardboad and then plywood.
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
Laminate flooring and Pool Table OBaNioN Flooring 2 06-05-2008 10:45 PM
Is foam needed when floating hardwood floor? digexpressions Flooring 8 02-24-2008 07:16 PM
engineered hardwood installation; Floating or Glue? El Buey Flooring 4 08-17-2007 03:53 PM
Pool Table Light in Drop Ceiling JJdeadhead Electrical 5 04-18-2007 09:01 AM
