Old 04-06-2008, 08:39 PM   #1
Polyurethane on wood floors -- What is this "wet edge"?
I'm going to polyurethane my wood floors tomorrow. What is this "wet edge" that they keep talking about? Also, what's the best thing to apply polyurethane with---brush? rag? mop on a stick? wools lamb? stain brush? The product is Minwax, and I believe it's oil-based; it's called Minwax Polyurethane Floors. Also, what is a T-bar?
proofer is offline   Reply With Quote
Old 04-06-2008, 09:08 PM   #2
as you apply the poly do not let the edge dry out or you will always have a ridge that you can see in the finish. i have good luck with a 1/4 inch nap roller. throw away after each use. light sand and damp cloth clean between coats. always use a GOOD quality finish or you will redo often
jason h is offline   Reply With Quote
Minwax Polyurethane vs. Minwax Polyurethane Floors proofer Flooring 3 04-06-2008 09:48 AM
Staining Wood Floor -- Use Polyurethane or FLOOR Polyurethane? proofer Painting 2 04-05-2008 08:47 PM
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 12:03 PM
Wood floors shelbytri General Discussion 6 08-19-2007 12:45 PM
Washing my wood floors J187 Flooring 1 11-14-2006 11:13 PM
