-   -   Polyurethane on wood floors -- What is this "wet edge"? (http://www.diychatroom.com/f5/polyurethane-wood-floors-what-wet-edge-19575/)
proofer 04-06-2008 07:39 PM
I'm going to polyurethane my wood floors tomorrow. What is this "wet edge" that they keep talking about? Also, what's the best thing to apply polyurethane with---brush? rag? mop on a stick? wools lamb? stain brush? The product is Minwax, and I believe it's oil-based; it's called Minwax Polyurethane Floors. Also, what is a T-bar?
jason h 04-06-2008 08:08 PM
wet edge
as you apply the poly do not let the edge dry out or you will always have a ridge that you can see in the finish. i have good luck with a 1/4 inch nap roller. throw away after each use. light sand and damp cloth clean between coats. always use a GOOD quality finish or you will redo often
