Polyurathane Pooling In The Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-30-2012, 07:35 PM   #1
Polyurathane pooling in the floor
What is the best way to get out the pooling their are 3 spots where the urathane puddled and it is quite noticeable?
mc8787 is offline   Reply With Quote
Old 07-30-2012, 07:42 PM   #2
Rewards Points: 14,026
Only way to get pooling is to have low spots in the floor.
Sand it again holding the sander flat and reseal.
Old 07-31-2012, 11:17 AM   #3
Rewards Points: 264
You will need to buff and recoat the floor again. If buffing aggressively in the pooled spots does not work then you can take a carbide scraper and lightly scrape out the pool, Then buff over the area and recoat again.
Awoodfloorguy is offline   Reply With Quote
water pooling in air handler Heil ebx3600a SouthLake HVAC 12 07-21-2012 01:56 PM
Polyurathane or silicon caulk outside? BlueBSH Building & Construction 5 01-12-2012 01:26 PM
Pooling water in shutoff Wapmiasomey General DIY Discussions 3 12-22-2011 10:34 AM
water pooling around garage door ljr General DIY Discussions 4 03-01-2011 12:46 AM
water pooling ontop of water heater nannerkrns Plumbing 2 09-23-2008 10:04 PM
