Old 09-30-2008, 11:47 PM   #1
polystyrene under basement pad
I am building a wood basement with a concrete floor and am wondering about insulating under it. I have a concrete footing with tamped gravel under the floor. My plan is to lay poly over the gravel and then 1" extruded polystyrene and then 3 inches of concrete. Are there any concerns I should have as far as condensation happening on top of the insulation and wrecking the concrete?
billybarty is offline   Reply With Quote
Old 10-01-2008, 07:54 AM   #2
i wouldn't bother as ambient earth temp's about 65f,,, insulation only affects the transfer rate of heat to cold. poly & 4"'d be my choice.
yesitsconcrete is offline   Reply With Quote
Old 10-01-2008, 09:04 PM   #3
I never mentioned that its a walkout so the front of the basement floor should be a lot colder than the back. Frost level here is about 8 feet and can get very cold.
Old 10-02-2008, 06:05 AM   #4
sandbagger !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
frost protection makes lotsa sense, then,,, on the footer's face & up the backside.
now, anything else you'd like to throw into the pot ? ? ?
Old 10-02-2008, 02:15 PM   #5
Yeah, I have some questions about sheeting and insulation but I'll put it in the construction forum. Thanks for the advice. And just to be clear, if I lay poly over top of the gravel and then put 1" polystyrene and then the concrete there won't be a condensation problem?
Old 10-02-2008, 03:16 PM   #6
Moderator
Termite's Avatar
I'd put the vapor barrier on the "warm" side of the insulation. That would be right under the concrete. I doubt you'll have any trouble either way though.
Old 10-02-2008, 05:16 PM   #7
RippySkippy's Avatar
My basement has (top down) 4" concrete, radiant heat, 2.5" Owens Corning Formular 250, and I don't recall the thickness..but plastic. It's the driest basement I've ever had...and no, there's no condensation that I'm aware of.
On a side note...not all foam is rated for under slab installation, make sure to use the right product.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Sunlight for a Basement Room prglor Remodeling 1 08-31-2008 05:29 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
