Old 05-30-2009, 11:22 PM   #1
toolbelt Tina's Avatar
Poly behind cement board?
I am building a custom shower. Some of my research revealed placing poly on the studs behind the cement board. Can anyone comment on this?
toolbelt Tina is offline   Reply With Quote
Old 05-30-2009, 11:52 PM   #2
Poly behind if you won't be applying a waterproof coating to the surface of the CBU. If you'll be waterproofing the CBU, not poly behind. If you do both, there's concerns about traping moisture between the layers. One or the other it what most will tell you.
Redguard is a popular waterproof coating. Schluter Kerdi is becoming very popular. It's a bonded waterproof sheet membrane. I use Prospec B-6000 but I don't think you can get this retail. MAPEI's Mapelastic HPG is popular as well.
KHouse75 is offline   Reply With Quote
Cement board meets drywall? CowboyAndy Drywall & Plaster 8 12-25-2010 09:29 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 10:41 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 11:32 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 03:25 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
