Old 10-03-2012, 12:07 PM   #1
plywood subflooring
should a plywood subfloor that is above a dirt crawl space be primed before putting down the finished floor. Finished floor will be either carpet or laminate.
Bruce Scariano is offline   Reply With Quote
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Another thread about subflooring & underlayment choices for a first timer DIY tiler pmergler Flooring 8 07-11-2010 03:00 AM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
