Remodelling small bathroom and took subfloor down to 3/4 planks that were installed on a 45 degree angle. Then installed 3/4 ext. grade plywood with 3" screws and construction adhesive. On top of that I installed 1/4 inch Hardibacker on top of a 1/4 inch modified mortor base and screwed it down with 1 1/4 backer screws. All went fine and I staggered all hardi joints with those in the plywood except in one spot. Where I had to cut out for the toilet flange I used two pieces of plywood to work around the drain pipe. I did the same exact thing for the hardibacker. The floor is solid as a rock and I did leave 1/8 to 1/4 around perimeter of room and between plywood and hardibacker. I plan to tape and mortar the seams with fiber mesh. I am a little concerned about the one seam where I did not stager the joints. I would appreciate any suggestions from personal experience. What are the chances of this causing cracks in tile or grout?
I did screw the 3/4 inch plywood into the joists (treated as if the planks were not even there. The 1/4 inch hardibacker was screwed to the plywood only. I guess I did make a few mistakes...anything worth redoing at this time in your opinion?
Yes I plan to have all seams tapes when the tile is set. Do I need to tape the seams under the bathtub?
When do the other bathroom you can make the cut in the hardi at right angles to one in plywood.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
