Plywood Sub Floor Over Concrete Slab - Flooring - DIY Chatroom Home Improvement Forum
Old 07-09-2011, 03:53 PM   #1
Plywood sub floor over concrete slab
Need a little guidance here....have a concrete slab that was carpeted, mrs. decided she wants wood floor. So carpet is gone, concrete floor is sound, and moisture free. Due to transitions between two other rooms (one is 3/4" hardwood over 1/2" plywood over concrete slab, the other is kitchen ceramic tile).
My "plan" is to lay down 6mil plastic moisture barrier, then 1/2" plywood, and then 3/4" hardwood. This decision was made because I would like the transition from the existing adjoining wood floor to the new one to be "level".
Question is, what is the best way to attach the new 1/2" ply to the concrete? Power Nailer? Adhesive Glue? or?
My first thought was a "engineered" floor and glue down operation....but this is a dining room with some pretty heavy furniture, and not sure how it will hold up with 10 dining room chairs sliding around on it.
Comments and suggestions welcomed! Thanks in advance....
targeted4u is offline   Reply With Quote
Old 07-09-2011, 07:43 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
The plastic against concrete will cause moisture condensaton and eventually mold.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 07-09-2011, 07:50 PM   #3
So what would be the better method of sealing the concrete against moisture forming? I was considering/thinking about sealing/ "painting" the concrete surface first.....then the moisture barrier, then the plywood, then the hardwood. The floor will no doubt outlive me anyway!
Old 07-09-2011, 09:06 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
Plywood on a slab is NEVER a good idea. Installing plastic under it is even worse. If there's moisture, where do you think it's gonna go? The moisture has to evaporate into the room. If there's too much moisture, you need to find the fix for that first.
Jaz
The Following 2 Users Say Thank You to JazMan For This Useful Post:
Bud Cline (07-10-2011), rusty baker (07-09-2011)
Old 07-09-2011, 09:10 PM   #5
Rewards Points: 126
I agree Jaz, plywood on slab is a failure waiting to happen, but some people are convinced it will work.
Old 07-10-2011, 01:52 PM   #6
Thanks for your input.....but we have been in this house for 6 years, two of the existing hardwood floor rooms with the same set up that I am trying to duplicate, have shown no evidence of having mold problems (yet).
Old 07-10-2011, 02:17 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Thanks for your input.....but...
You guys should have seen that commin'.
XXX
Old 07-10-2011, 03:55 PM   #8
Rewards Points: 126
Yep, that's why I posted.
The Following User Says Thank You to rusty baker For This Useful Post:
Old 07-10-2011, 06:45 PM   #9
So again I thank ya'll for your informed input, although no one has mentioned my original request for "guidance" on attaching plywood to the dry cement slab.
This wasn't a brain storm I just came up with on my own idle time....did some online research first on vapor barrier/plywood sub/and hardwood install...
One of the references I used I took some reference from: http://www.hardwoodcouncil.com/about.php, and their install guidelines.
But as I often tell my clients, opinions are like "noses" everyone has one, and one of my personal favorites......"it must be true, I read it on the Internet".
Again...thanks to all who chimed in.......
PS: Talked to former owner of our house tonight, the "existing wood floor" was installed in 2000....so if this install lasts another 11 years it will probably outlive me..........
Old 07-10-2011, 10:00 PM   #10
Rewards Points: 126
Good luck. Sometimes things work, even tho they are not done right.
Tags
concrete slab , engineered floor , glue , nail , plywood subfloor
Cement backer board over kitchen concrete slab gtimk4 Flooring 2 02-19-2012 02:46 PM
Insulating Split-Level Ground Floor Concrete Slab illusion8055 Building & Construction 7 03-02-2011 08:26 PM
How do I install insulation to floor joist setting on a concrete slab TimmyP Building & Construction 6 01-25-2011 11:53 AM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 10:37 AM
Remodel over sloped concrete slab PSL_Hokie Building & Construction 11 07-11-2007 05:14 PM
