Plywood Over Subfloor Before Laminate - Flooring - DIY Chatroom Home Improvement Forum
Old 06-28-2013, 05:28 PM   #1
jkk
Rewards Points: 233
Plywood over subfloor before laminate
Need to avoid lips at transitions to kitchen, foyer and bathrooms, so I'm laying down 1/2 plywood before we put down laminate. Does it matter what type/grade of plywood we use? Trying to keep cost down on the filler material.
jkk is offline   Reply With Quote
Old 06-28-2013, 06:44 PM   #2
DIY staff
Rewards Points: 7,174
Not a big concern---OSB would work for the filler--
Old 06-28-2013, 07:07 PM   #3
Rewards Points: 13,732
I would not use CDX. Full of voids in the core.
rusty baker (06-28-2013)
Old 06-28-2013, 08:28 PM   #4
jkk
Rewards Points: 233
Can I use 1.5" screws to attach this 1/2" to the 3/4 tongue and groove?
Or do I need to screw the 1/2" into the joists?
Old 06-28-2013, 09:59 PM   #5
Underlayment does not get screwed to the joist.
That's going to be a heck of a lot screws, it needs to be attached every 4" on the edges and 6 to 8" in the field.
A whole lot faster to used ring shanked #8 nails in a nail gun.
Old 06-29-2013, 07:18 AM   #6
jkk
Rewards Points: 233
Yeah that's a good idea. I am using 2.5" screws on the t&g to eliminate squeaks so I was in the screw mindset. Nailing will be cheaper/faster.
May as well buy the gun to complement my 18 and 16 gauge guns.
Re-using laminate wingman1153 Building & Construction 10 04-30-2013 11:51 AM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
