Plywood Over Gypcrete? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-20-2008, 11:06 AM   #1
plywood over gypcrete?
Is it possible to install plywood over gypcrete? If so, how would you do this? It is NOT possible for us to take out the gypcrete as we live in a condo.
Shell
Shell_Lee is offline   Reply With Quote
Old 06-20-2008, 11:31 AM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
Shell
Why do you want to do this?
Angus
My Albums
angus242 is offline   Reply With Quote
Old 06-20-2008, 11:36 AM   #3
We are hoping to install a hardwood floor. It would not be a floating kind though. With everything that I have read out there, you are not to glue hardwood or nail hardwood to gypcrete. If we would install plywood over the gypcrete, then we would have a surface to install the hardwood.
Old 06-20-2008, 11:43 AM   #4
angus242's Avatar
What about a moisture barrier and sleeper setup?
What about an engineered floating hardwood setup?
Angus
My Albums
Old 06-20-2008, 11:47 AM   #5
The gypcrete is already there, so installing sleepers is not an option. We were really hoping NOT to use a floating hardwood floor though.
Old 06-20-2008, 12:04 PM   #6
angus242's Avatar
Well I'm not a hardwood installer but I know of installs with plywood on top of gypcrete. Obviously, there's a moisture situation to deal with so I assume it needs to be sealed before the plywood is laid. I guess I'd be worried about how the plywood is attached to the gypcrete. Tapcons I assume but I'd also be worried about damaging the gypcrete.
Also, I believe you'd need at least 3/4" ply to account for the hardwood nails so you'd need to address the added floor height. Will it be a problem with any adjacent flooring (including base moldings)? Door jambs?
Sorry I couldn't be of more help.
Angus
My Albums
Old 06-20-2008, 12:11 PM   #7
I have read somewhere that there is a kind of glue that can be used to lay down the plywood. I don't know what kind it is though. Yes, we were kind of worried about adding the additional height too. The base molding is not a problem as we are replacing all of it.
I didn't know that we had gypcrete until yesterday when I pulled up an edge of carpet and took a tack strip out by the bathroom door. Heck, I hadn't even heard of gypcrete until yesterday. I just assumed that we would have a plywood subfloor. Was I WAY off. lol
Old 06-20-2008, 12:20 PM   #8
angus242's Avatar
I wouldn't do that! Adhesives and gypcrete are NOT a combo I'd mess with.
Seriously, start considering engineered floating. No height issues and it's a very durable product. Find a showroom in your area and go see it in person. I recently did some tile work in a brand new condo off Michigan Ave in Chicago (prolly $1 mil for under 1000 sq ft) and they had engineered cherry. Absolutely not the same as 3/4" nailed hardwood, but definitely very, very nice.
Good luck
Angus
My Albums
Old 06-20-2008, 04:34 PM   #9
any word on schon engineered flooring?
kshankle is offline   Reply With Quote
Old 06-20-2008, 04:54 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Condos have rules, better talk to those guys first.
Old 06-20-2008, 06:33 PM   #11
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Good luck
I am completely in agreement with every last word posted.
- Build Well -
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 06:29 AM
large mystery plywood panel in garage - any thoughts on this?! joeyboy General DIY Discussions 15 12-02-2007 03:01 PM
Plywood replacment FatAugie Roofing/Siding 3 09-04-2007 10:52 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 08:48 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
