On Plywood Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 09-07-2012, 09:46 AM   #1
on plywood flooring
Can I Apply Thinset Over Zinsser Primer
Dennis Hilchey is offline   Reply With Quote
Old 09-07-2012, 12:04 PM   #2
Rewards Points: 13,446
Can you fill in the blanks for use?
What is it your really trying to do?
If your thinking of tiling right over plywood hold up.
Old 09-07-2012, 09:52 PM   #3
Rewards Points: 264
I am assuming you want to install tile to the plywood. If this is the case I would suggest attaching a cement board to the plywood and then install the tile. It will make for a much better job.
Awoodfloorguy is offline   Reply With Quote
Old 09-08-2012, 10:17 AM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Here is a method that will work.
http://www.ronhazelton.com/projects/...e_over_plywood
This italian guy is no joke!
JetSwet is offline   Reply With Quote
Old 09-10-2012, 04:18 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 340
Not sure why you think using "thin skin" is such a good method. But it needs to be bonded to the substrate like anything else. So, Can I Apply Thinset Over Zinsser Primer?
What makes you think Armen is italian? Why does it matter?
Jaz
Old 09-10-2012, 04:45 PM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
Um?.... because he looks like Mario from Mario brothers. Lol
Luan Plywood Underlayment BigJim Flooring 12 03-05-2013 04:41 PM
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-18-2012 11:51 PM
Can I Paint a Plywood Subfloor? LMS1213 Flooring 31 05-06-2012 09:33 AM
Tile Plywood Sub-Floor Help woodlab Flooring 1 10-21-2008 10:58 PM
