Old 01-14-2013, 08:11 PM   #1
plywood attatchment
What is the best adhesive to use between a particle board subfloor and 3/4 in plywood on top (nailed or screwed to floor joist) ?
hidden1 is offline   Reply With Quote
Old 01-14-2013, 08:15 PM   #2
Doer of Many Things
poppameth's Avatar
plywood attatchment
Particle board should not be used as subfloor (or anything else in my opinion.) Underlayment is not glued to the subfloor. Studs are in the walls, joists are in the floor.
poppameth is offline   Reply With Quote
The Following User Says Thank You to poppameth For This Useful Post:
rusty baker (01-14-2013)
Old 01-14-2013, 08:19 PM   #3
plywood attatchment
Originally Posted by hidden1 View Post
What is the best adhesive to use between a particle board subfloor and 3/4 in plywood on top (nailed to studs) ?
#1 What's the finished floor going to be?
#2 Studs are in a wall, joist are what the floor and ceiling are attached to.
If it's really partical board and not OSB it really needs to go before anything else goes down.
If partical board gets wet once it turns to oatmeal.
Just the rising humity under it can cause it to swell.
The only glue used should be constrution adhesive and that only goes on top of the joist, where the subflooring is nailed down.
Glue is never used between layers of subflooring or underlayment.
Old 01-14-2013, 08:21 PM   #4
plywood attatchment
the particle board definitely has to go. if you install plywood over your subfloor that is getting tile do not glue it and do not screw into the joists.
Old 01-14-2013, 08:34 PM   #5
plywood attatchment
none of that will be a issue with vinyl..and will be no seams .
Old 01-14-2013, 09:10 PM   #6
plywood attatchment
If you say so
The second layer is laid so the seams do not line up with the seams below and is not nailed into the joist, only between the joist.
Partical board will not hold nails and will just blow through.
So the plywood layer will not be properly attached.
Old 01-14-2013, 10:48 PM   #7
Pro Flooring Installer
rusty baker's Avatar
plywood attatchment
And gluing the plywood to particle board is a no-no. Besides, it won't hold.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 01-14-2013, 10:57 PM   #8
Moderator
plywood attatchment
http://www.apa-europe.org/Languages/.../PDF/R340G.pdf
Gary
Clothes taking longer to dry?
Roofing plywood advice needed jimd206 Roofing 2 04-25-2011 12:58 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
