-   -   plywood attatchment (http://www.diychatroom.com/f5/plywood-attatchment-169146/)
hidden1 01-14-2013 08:11 PM
plywood attatchment
152 Attachment(s)
What is the best adhesive to use between a particle board subfloor and 3/4 in plywood on top (nailed or screwed to floor joist) ?
poppameth 01-14-2013 08:15 PM
Particle board should not be used as subfloor (or anything else in my opinion.) Underlayment is not glued to the subfloor. Studs are in the walls, joists are in the floor.
joecaption 01-14-2013 08:19 PM
Originally Posted by hidden1 (Post 1093629)
What is the best adhesive to use between a particle board subfloor and 3/4 in plywood on top (nailed to studs) ?
#1 What's the finished floor going to be?
#2 Studs are in a wall, joist are what the floor and ceiling are attached to.
If it's really partical board and not OSB it really needs to go before anything else goes down.
If partical board gets wet once it turns to oatmeal.
Just the rising humity under it can cause it to swell.
The only glue used should be constrution adhesive and that only goes on top of the joist, where the subflooring is nailed down.
Glue is never used between layers of subflooring or underlayment.
DannyT 01-14-2013 08:21 PM
the particle board definitely has to go. if you install plywood over your subfloor that is getting tile do not glue it and do not screw into the joists.
hidden1 01-14-2013 08:34 PM
152 Attachment(s)
none of that will be a issue with vinyl..and will be no seams .
joecaption 01-14-2013 09:10 PM
If you say so:)
The second layer is laid so the seams do not line up with the seams below and is not nailed into the joist, only between the joist.
Partical board will not hold nails and will just blow through.
So the plywood layer will not be properly attached.
rusty baker 01-14-2013 10:48 PM
And gluing the plywood to particle board is a no-no. Besides, it won't hold.
Gary in WA 01-14-2013 10:57 PM
http://www.apa-europe.org/Languages/.../PDF/R340G.pdf
Gary
