Old 10-09-2012, 02:41 PM   #1
plywood & cement
we have added on to our laundry room and built up the new part of the floor with plywood. It is not level with the existing concrete floor. We want to lay ceramic tile or possibly vinyl tile over the entire floor. How can we bring the concrete portion of the floor up to the same level as the new plywood floor? It's maybe a 1/2 inch; difference, if that much. Thanks.
benben is offline   Reply With Quote
Old 10-17-2012, 06:09 PM   #2
plywood & cement
This is an easy one get some Ardex self leveling concrete it mixes up to a watery consistency and pour it on until they are level follow the directions on the bag and you should have no problem.
Jim Decker is offline   Reply With Quote
The Following User Says Thank You to Jim Decker For This Useful Post:
benben (10-22-2012)
Remolding bathroom cement board on plywood JohnRoss Building & Construction 1 08-05-2011 09:28 PM
Roofing plywood advice needed jimd206 Roofing 2 04-25-2011 12:58 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
