Old 06-13-2009, 09:12 PM   #16
Tileguy
Bud Cline's Avatar
Which Plywood?
3/8" minimum thickness.
Old 06-19-2009, 04:42 PM   #17
Which Plywood?
ok, so ive decide to just lay another layer of exterior grade plywood on top of the non-exterior grade plywood at the thickness you mentioned above. Any suggestions about seams (especially the seam created when I put the exterior grade plywood against the tub. I don't want water going down the wall of the tub onto the first layer of plywood) so water wont get to the second layer of plywood?
MrRyan001 is offline   Reply With Quote
Old 06-20-2009, 05:24 PM   #18
Tileguy
Bud Cline's Avatar
Which Plywood?
Caulk the plywood to the tub.
Caulk the tile to the tub.
Seal the grout. (For what that's worth!)
Use a shower door or curtain.
Use a bath mat.
Control the kids.
Wash the dog outside.
Old 06-23-2009, 03:41 PM   #19
Tileguy
Bud Cline's Avatar
Which Plywood?
In my opinion you should choose a higher quality plywood.
Such as - WHAT?
What is wrong with using the plywood recommended by the entire industry as MrRyan001 has decided to do?
Old 06-23-2009, 07:16 PM   #20
Custom Cabinet Maker
Which Plywood?
This may sound crazy but: Since I have to presume the first layer is the first layer on the joists and usually not water resistant, I may just go get a gal or so of waterbased poly and just really have at it, do the GOOD caulk at the tub, then put second layer and caulk again at tub.
at least that will really slow down any absorbtion of moisture in the base layer.
skymaster is offline   Reply With Quote
Old 06-23-2009, 07:29 PM   #21
Tileguy
Bud Cline's Avatar
Which Plywood?
Yup sure does!
I think the imagined issue is being over analyzed.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 07:29 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
