Old 10-13-2011, 02:36 PM   #1
ply wood
can I paint a plywood subfloor. The carpet is ready to go into someone's dump. Can't clean it anymore and can't afford new floors at this time. Seems like I saw on one of the home improvements shows that they stained each piece of plywood underneath the carpet a diffrent color stain and it looked pretty good. What do you think of this?
boopie03 is offline   Reply With Quote
Old 10-14-2011, 10:54 AM   #2
ply wood
You can do whatever you would like to the floor. Paint will cover the best and hide all imperfections. If the plywood is stained from spills and cleaning, a wood stain would not cover well. Keep in mind what you intend to install in the future. If you need to glue anything down, the plywood is porous and allows glue to seep into it forming a better bond. If you paint it, you'll remove this ability to absorb the glue.
yeag6154 is offline   Reply With Quote
Old 10-14-2011, 01:10 PM   #3
Tileguy
JazMan's Avatar
ply wood
And if you keep the plywood as "the" flooring, remember it's not sanitary and splinters will be a problem.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Sister joist, replace wood bean, what wood grain? jpcada Building & Construction 14 04-13-2010 08:46 AM
Replacing Carpet on Stairway with Wood jkirby39 Carpentry 3 01-24-2009 01:42 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
DAP caulking question n0c7 Painting 16 11-01-2008 12:31 AM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 10:14 AM
