Plumb Line Under Tile Adhesive - Flooring - DIY Chatroom Home Improvement Forum
Old 09-01-2012, 06:38 PM   #1
Plumb line under tile adhesive
I am laying tile for the first time. I have prepped the floor and am ready to lay out the tile and start cutting and gluing down the tile.
I have seen video tutorials about putting down a chalk line, but how do you line up the tile to the line if the floor is covered with adhesive?
BamaGary is offline   Reply With Quote
Old 09-01-2012, 06:57 PM   #2
Rewards Points: 12,790
You need to be using thin set in a bag that you mix up not some tile glue or mastic.
Use red chaulk, easer to see and will not just wipe off.
Old 09-01-2012, 07:18 PM   #3
DIY staff
Rewards Points: 7,174
Most tile setters snap the lines---a grid ,actually that holds four tiles(4 square foot)---then spray the line with hair spray or clear lacquer,to keep the lines from getting wiped off during sweeping.
I would not use red chalk--it will get on your shoes and may ruin carpet as you walk around the house.
I usually set two squares at a time---about 8 square foot---leaving the down line exposed---
user1007 (09-01-2012)
Old 09-01-2012, 09:25 PM   #4
Pro Flooring Installer
rusty baker's Avatar
You are not supposed to use red chalk on any flooring product. It will bleed thru vinyl, stain carpet, etc.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following 2 Users Say Thank You to rusty baker For This Useful Post:
oh'mike (09-01-2012), user1007 (09-01-2012)
Old 09-01-2012, 09:50 PM   #5
DIY staff
Thanks Rusty--I was trying to be tactful---I use orange or blue on concrete---then spray down the lines---red is only used for rough framing---darn permanent color---I sure don't want to buy someone a new rug.
Old 09-01-2012, 10:53 PM   #6
We carpet and vinyl installers use white only. I have seen blue and/or red used on vinyl and it came thru the seams.
The Following User Says Thank You to rusty baker For This Useful Post:
Old 09-01-2012, 11:19 PM   #7
DIY staff
good to know---I've never tried white--- bet that white is easy to accidentally wipe off before it been sprayed down
Using steel instead of tile on a wall, what adhesive to use? swsengineer Tiling, ceramics, marble 4 02-07-2012 09:12 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
tile adhesive wondwossen Tiling, ceramics, marble 3 10-16-2009 06:13 PM
Tile Over Adhesive newbsauce Flooring 2 09-26-2009 11:45 AM
