-   -   Plumb line under tile adhesive (http://www.diychatroom.com/f5/plumb-line-under-tile-adhesive-155515/)
BamaGary 09-01-2012 05:38 PM
I am laying tile for the first time. I have prepped the floor and am ready to lay out the tile and start cutting and gluing down the tile.
I have seen video tutorials about putting down a chalk line, but how do you line up the tile to the line if the floor is covered with adhesive?
joecaption 09-01-2012 05:57 PM
You need to be using thin set in a bag that you mix up not some tile glue or mastic.
Use red chaulk, easer to see and will not just wipe off.
oh'mike 09-01-2012 06:18 PM
Most tile setters snap the lines---a grid ,actually that holds four tiles(4 square foot)---then spray the line with hair spray or clear lacquer,to keep the lines from getting wiped off during sweeping.
I would not use red chalk--it will get on your shoes and may ruin carpet as you walk around the house.
I usually set two squares at a time---about 8 square foot---leaving the down line exposed---
rusty baker 09-01-2012 08:25 PM
You are not supposed to use red chalk on any flooring product. It will bleed thru vinyl, stain carpet, etc.
oh'mike 09-01-2012 08:50 PM
Thanks Rusty--I was trying to be tactful---I use orange or blue on concrete---then spray down the lines---red is only used for rough framing---darn permanent color---I sure don't want to buy someone a new rug.
rusty baker 09-01-2012 09:53 PM
We carpet and vinyl installers use white only. I have seen blue and/or red used on vinyl and it came thru the seams.
oh'mike 09-01-2012 10:19 PM
good to know---I've never tried white--- bet that white is easy to accidentally wipe off before it been sprayed down
