Old 06-12-2009, 03:34 PM   #1
plugging holes left from radiator removal
I had radiant heat installed and removed the baseboard heaters. I now have small 3/4" holes in floor where the copper radiator pipes came up. What's the best way to plug these up? after they are plugged, I would like to then patch them with pad and carpet in the living room and linoleum elsewhere to minimize the eyesore effect. I'm a total noob when it comes to home improvement.
dlaplant is offline   Reply With Quote
Old 06-12-2009, 05:13 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Find some dowels that fit tight. Cut them slightly longer than you need. Put wood glue on them and drive them in the holes. After the glue dries, use a flexible hand saw and trim them flush.
foundation weep holes for drainage shama144 Building & Construction 12 12-31-2011 12:17 PM
Block Foundation w/Hundred Seep Holes? Jodust11 Building & Construction 9 04-13-2010 11:41 AM
holes left by curtain rod screws/anchors..what to do? talula79 Painting 4 06-03-2009 10:05 AM
Re-using post holes in concrete philS Building & Construction 8 05-04-2009 09:15 AM
drilling vent holes ape Roofing 4 10-15-2007 05:36 PM
