Please Help! How To Fix Hole In Concrete Floor Before I Tile Tomorrow? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 08:00 PM   #1
PatrickGSR94's Avatar
Rewards Points: 87
Please help! How to fix hole in concrete floor before I tile tomorrow?
While scraping the glue on my kitchen floor to prepare for tile tomorrow, I came across this area in my pantry. On the other side of this wall is the water heater in the garage, and apparently the idiot builders ran the hot water piping below slab and left a massive hole surrounding it. They filled it in with whatever those white chunks are, which heaved up a bit above the floor level.
So, what can I use to fix this before I start laying tile tomorrow morning? I'm planning to rent a wet saw for 24 hours so it will have to be back by the same time Friday morning. I might can just leave the tiles out of that area for a bit if need be, and just cut them, until I figure something out for this.
Does anyone make a kind of premixed concrete or concrete filler that I can dump in there and then spread thin-set over it and tile?
PatrickGSR94 is offline   Reply With Quote
Old 03-09-2011, 08:31 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
So, how deep is it? Doesn't look too wide, maybe 1 1/2" max. Thin set should do it.
Jaz
Old 03-09-2011, 08:32 PM   #3
Rewards Points: 87
Well, there is no slab where the hole is. It's just the exposed dirt. Maybe some non-shrink grout, like the kind used in concrete masonry and underneath base plates of structural steel columns?
Old 03-09-2011, 09:18 PM   #4
firehawkmph's Avatar
Rewards Points: 1,922
Patrick,
If you can dig some of that dirt out so your hole is at least an inch deep, get a bag of fast set concrete mix at the big box stores. It sets up in about a half hour. It won't take much to fill that hole. Just smooth it out real nice with a steel trowel so nothing is sticking up above the rest of the floor.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-09-2011, 10:15 PM   #5
Not sure but don't you have to prep the original floor with a concrete treatment so any new material will bond to it??
Fantastic is offline   Reply With Quote
Old 03-09-2011, 11:33 PM   #6
Rewards Points: 87
You mean for the tile? I just spent nearly 12 hours scraping the vinyl flooring adhesive off all areas that will be tiled tomorrow. I've never heard of any concrete "treatment" needed before laying tile on a concrete slab.
Old 03-09-2011, 11:35 PM   #7
Rewards Points: 87
Originally Posted by firehawkmph View Post
Patrick,
Mike Hawkins
The hole is at least 2-3" deep already, from what I can see. Are there small bags of the fast setting stuff available? I don't need an 80 lb. bag or anything.
How about this stuff? Says it expands so I'm not sure if that would work for keeping the top finished surface level.
http://www.lowes.com/pd_41333-96-009...051&langId=-1#
Old 03-10-2011, 02:42 PM   #8
Not for tile but for any new concrete or SLC that you use to patch/fill a hole in concrete. I believe its to ensure the new material/substance bonds to the old concrete?? Again not 100% sure about this?
Old 03-10-2011, 05:59 PM   #9
Patrick,
Get the fast set concrete, use what you need and throw the rest away. I think its around $7. You don't need any special 'treatment' for the new concrete patch, or the old concrete for that matter. If you have scraped off any lumps sticking up, then go over it with your shop vac so there isn't any dust of debris.
Mike Hawkins
Old 03-10-2011, 08:13 PM   #10
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...but you will need to use "modified thinset mortar" to install the tile. Don't use the unmodified thinset it won't bond to the remnants that are there. And don't use the premixed thinset, it won't work either.
How much did you pay for the thinset?
XXX
Old 03-13-2011, 07:49 PM   #11
Rewards Points: 87
Hey all, I just finished laying all my tile about 6 a.m. this morning I left out 2 tiles where the hole is and will deal with it on another weekend. I just had to get the rest of the floor done ASAP so I can get cabinets and appliances back in.
I did pick up a 10 lb. pail of Quickrete fast-setting concrete the other day, and it was indeed around $7. As for the thinset, I used Mapei Ultraflex 2 modified thinset which was around $25/50 lb. bag at Lowe's.
My boss suggested sticking a piece of vapor barrier in the hole over the dirt before I put the concrete in, but I'm not sure if I can really get my hand in the hole, nor can I even see the other edges of the hole. My water heater is elevated on a platform in the garage on the other side of the wall, and the platform has drywall all around it. I dunno, I might pull that off since I've been wanting to redo that drywall on the platform anyway.
The dirt inside the hole does seem quite dry, so I'm not sure if a vapor barrier would really be necessary or not.
Old 03-13-2011, 09:08 PM   #12
Sounds good Pat,
I wouldn't worry about a vapor barrier in that small of a hole. If it's dry like you say, you shouldn't have a problem. Laying tile at 6 am? You wildman you. Better start laying off the coffee late at night.
Mike Hawkins
Old 03-14-2011, 12:35 AM   #13
Rewards Points: 87
Actually I didn't even have dinner the evening before, was working with a bucket of thinset and couldn't stop.
The little pantry room (where the hole is) took me about 3 hours to lay the tile due to the extremely tight space, shelves on both sides in the way, having to constantly sweep out debris, having to stop and make a new batch of thinset, etc. Could also be my obsessive compulsive perfectionism lol
Old 03-14-2011, 03:20 PM   #14
I had this exact problem in my bathroom when I removed the vinyl to put down tile. The wet wall has a hole in the slab for the pipes, and the hole extended past the wall into the room, just like your picture, even complete with chunks of white material.
I bought bag of quick setting concrete, smallest was I think 50 or 60lbs and was $7-8
I knocked off all the loose white stuff and any other pieces of concrete that was loose. I used a wire brush to make sure all loose stuff was off and to rough up the surface, then used a vacuum to clean it.
I placed a piece of cardboard against the water pipes to act as a dam, I did not want to completely fill the hole because of the water pipes comming through
Using a spray bottle, thoroughly dampen the old surface
Prepared the quick concrete and poured it in, for my patch I needed about 6lbs.
Using the spray bottle kept the area moist while it cured.
It worked great. About 45 minutes start to finish to prep, patch and cure. By the time I had tiled up to it, it was dry and ready for modified thinset and tile over, no issues.
FixitDragon is offline   Reply With Quote
Old 03-15-2011, 06:44 AM   #15
Rewards Points: 87
Awesome man, I'll give it a shot this week.
20x20 Porcelain Tile over Linoleum on Concrete Slab scbauer Tiling, ceramics, marble 3 08-31-2010 07:11 PM
Ceramic floor tile on concrete basement floor w/toilet pedestal amp2oo1 Flooring 1 10-05-2009 07:31 AM
Old Tile on Concrete floor bmenton Flooring 1 01-27-2009 06:53 PM
tile over exterior concrete? BlueMoonBean Flooring 6 11-18-2008 01:55 PM
Tile on concrete slab, ground level - bamboo? IvoryRing Flooring 2 06-28-2006 08:52 AM
