Please Help With Hole In Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-26-2008, 09:18 PM   #1
Please help with hole in floor
I am remodeling bathroom. Floor had mold which resulted in floor rot. Anyway, I cut it out and replaced most of the hole...however there is still a hole next to tub ( about 1inch wide by 4 inches long) and very jagged as you can tell. You will be able to tell the new floor and the old floor as well. I also have a couple small cracks as my measurements weren't the best. Are the small gaps ok to have? I will be putting backboard on next. I do not have any access from below. Thanks and any help would be greatly appreciated!
ahecei is offline   Reply With Quote
Old 02-26-2008, 09:53 PM   #2
Is this the toliet drain?
redline is offline   Reply With Quote
Old 02-26-2008, 09:59 PM   #3
help with floor hole
Yes, it is the toilet drain
Hardwood floor stripping problems cmdrico7812 Flooring 3 09-13-2011 10:58 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
Help wih floor extremer1519 Flooring 1 12-27-2005 06:33 PM
