Plank Sub-floor - Replace Or Overlay - Flooring - DIY Chatroom Home Improvement Forum
Old 02-24-2011, 07:03 PM   #1
Plank sub-floor - replace or overlay
Hello,
I am going to be redoing a floor in my house. The house is 25' wide, with an i-beam down the middle. The joists are 2x8's, 16" on center, the span is about 12 1/2' wide. I have plank sub-floor, 3/4" deep, about 8" wide that are installed at a 45 degree angle. The house is about 50 years old (1960 construction).
The floors are bouncy, and the planks are nailed in, so they squeak pretty good to. I am redoing a bedroom floor, and wanted to beef up the floor. Last year, I did a bathroom. I sistered the joists, and put down 3/4" T & G plywood. The sub-floor was replaced because the old one was rotting out. That floor is solid.
I plan on sistering the joists to stiffen the floor under the bedroom, but do I need to replace the plank sub-floor? Could I just screw it down? I know I could overlay with plywood, but then the floor height would not match in the hallway.
Any advice would be greatly appreciated.
Thanks,
Erik
erm213 is offline   Reply With Quote
Old 02-24-2011, 07:09 PM   #2
DIY staff
Rewards Points: 7,174
Screwing it existing planks down will be fine----Mike----
Old 02-25-2011, 08:35 AM   #3
Been at it for 45 years
This Old Spouse's Avatar
Rewards Points: 79
I don't see any reason to replace the planks if they're in good shape. Screw them down to minimize the squeaking and call it a day.
This Old Spouse is offline   Reply With Quote
Replace An Allure Flooring Plank galapas Flooring 3 12-09-2010 12:26 PM
Hardie Plank Siding - Sizes stubits Building & Construction 5 04-26-2010 01:32 PM
Acid etching and a cementous overlay? imola ghost Building & Construction 1 08-08-2009 04:56 AM
Overlay new shingles - Should I/Can I - do it? mikem57 Roofing/Siding 11 06-10-2009 09:31 AM
Old plank subfloor in old 1930 house-hardwoods? AllGoNoShow Flooring 1 04-29-2007 08:47 PM
