#1 |
Placing vinyl tile over linoleum
I have linoleum tile in my kitchen. It's the original ugly green stuff from when the house was built 25 years ago. I want to change to something else. I would like wood, but that would be about $1,500. If I use stick on vinyl, it would only be about $300. Can I put the stick on vinyl tiles over the existing tile? I really don't want to have to scrape it all up. Thanks.
#2 |
Tileguy
You've confused me.
Is it tile, linoleum, sheet vinyl or what? If it's in sheets, they are probably 6' or 12' wide and have some kind of pattern. So, the answer is no, you will not be able to get good results applying self stick tile of that kind of flooring. In addition, it is very likely your old sheet vinyl (?) has a thin foam layer and so the answer would always be no even if there was no pattern. Of course when people chose self stick tiles, they do so to cover a floor cheap. So if you don't expect long lasting results, vinyl tiles may be a good short term solution. But don't be surprised if the old pattern show thru and the new floor dents badly. Alternatively you should remove the old floor along with any 1/4" underlayment that it's stuck to and then prep the floor with an appropriate new underlayment and then new flooring. You should not just scrape the old vinyl off because if it's real old the backing may contain asbestos, plus it's just easier the other way. Jaz
Tile 4 You LLC Troy, MI KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME! |
#3 |
I'm not sure, it may be vinyl. It doesn't seem to be in sheets. More like one big piece cut out to fit the shape of the room. I could be wrong on that. I got down on my knees and looked, I couldn't find any seams. I also checked underneath it by pulling up a spot under the dishwasher. There wasn't anything under it but concrete.
#4 | |
Pro Flooring Installer
Placing vinyl tile over linoleumQuote:
"I'm twisted, not sick. Sick implies, I'll get better" Semi-Retired Installer Installing since 1973 |
#5 |
OK. I'm not too familiar with flooring stuff. That's why I'm asking about it.
#6 |
Peel and stick over vinyl would be a temporary solution. If you scrape up the old flooring be aware that the vinyl and/or adhesive "could" contain asbestos.
| Display Modes | |
| Vinyl self stick tile grout | cesuark | Flooring | 3 | 09-06-2010 04:13 PM |
| Peel and stick vinyl flooring over absteos tile? | Codchamp | Flooring | 3 | 07-17-2010 07:17 PM |
| Tile over vinyl | hmc | Flooring | 7 | 10-26-2005 12:05 AM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 1 | 03-19-2005 01:55 PM |
| Siding: Aluminum vs. Vinyl | Grumpy | Remodeling | 0 | 04-18-2004 04:35 PM |
