Old 07-19-2010, 02:47 AM   #1
Question
Pitched floor leveling issues.
Here's the issue:
Third floor of my house used to be the roof, a flat roof. House was built in 1885 and a third floor was added around 1920. Apparently they didn't care about the 8" difference over twenty feet.
Normally I would pull the sub-floor and sister joists to get my level floor. However, I am taking back the drywall on the second floor to the joists and using the old sub flooring as a ceiling. A new thread can be started on the aesthetics . This will achieve a twelve foot ceiling on the second, but takes away my option for leveling the floor on the third. This is all to say, if I sister new lumber, I will see it. As it is now, it is all 130 year old wood and looks nice.
As I said, it is quite a pitch, but the house is relatively small: 18' wide by 25' long. The third also has a pitched roof, so the "floorable" space is only 12' wide. Any creative recommendations/thoughts would be greatly appreciated. Again, there are no structural problems...the floor was meant to slope as it was built as a flat roof building. Thanks in advance.
uberdoom is offline   Reply With Quote
Tags
flooring, floors, level, sister, sloping
Spray foam - code issues? upinsmoke Building & Construction 1 05-10-2010 08:47 PM
Tubular Skylight - Flashing Issues lrsuffi@yahoo.c Remodeling 2 06-30-2009 06:07 PM
A/C Transformer buzz - high pitched sound ComfortSD HVAC 5 12-27-2008 02:37 PM
high pitched tone from boiler? LanterDan HVAC 4 09-26-2006 08:40 PM
