Pine Floor Install - Flooring - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 02:58 PM   #1
Lightbulb
Pine floor install
I'm getting ready to install 5" wide/ 3/4"/tounge and groove/kiln dried SYP in a beach house and have a few ?'s - we leave the heat at 40 degrees (when we are not there- 65 degrees when we are there) in the winter and leave the AC off in the sumer when we are not there( and maybe 70 degrees when we are there) - we're 5 blocks away from the water so our humidity level really isn't above normal for this area (MD)..my subfloor MC is 12%. When I acclimate the lumber to the house (for 10 days or so) should I turn the heat up to 60 degrees or so, or leave it down to 40 degrees ? Also, when installing, should I leave a small gap (1/2 of a dime or so) between the boards for summer expansion....and last but not least, what's the best paper (or tar paper) to put down on the subfloor and does it get overlapped? We are going for an antique look, so our plan was to install it now, but not to fininsh it (maybe w/ poly) until the summer...unless u think that's crazy...THANKS !!
ms21117 is offline   Reply With Quote
Old 10-23-2008, 06:40 PM   #2
Get out of the box!
Rewards Points: 260
12% is to high. You should not be above 10%
You need to dry it out in there and get the temp up to at least 65 for 48 hrs prior to install and 48 post install.
No need to the gap the boards with you high humidity levels.
If they dry out they will shrink, then you will have gaps you can loose more than a penny in!
15 mil tarpaer will work great.
Schluters Kerdi Shower System, Ditra. Loxcreens ProVa Mat Shower Systems
Konecto Luxury Vinyl Plank,Armstrong and Hardwood flooring.
https://IndianaFloorsLLC.com/default.aspx
26yrsinflooring is offline   Reply With Quote
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 09:24 AM
Installing Pine Panelling on Ceiling Gearbox Paul Carpentry 10 10-12-2008 11:13 PM
