Pine Floor ID Help! - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 08:04 AM   #1
Pine floor ID help!
Hello
I am looking for some help in identifying what type of pine floor I have in my living room. We will be tearing up the vinyl floor in the kitchen and would like to match the floor. I've been told it's Southern Longleaf Pine but when I compare it to other photos it doesn't seem to match. There are very few knots in the wood and the grain runs long and straight, any help would be appreciated, I live in Massachusetts and the floor was probably put down in the 1920s. The boards are 3 1/4" wide.
upslims is offline   Reply With Quote
Old 04-21-2013, 09:03 AM   #2
woodman58's Avatar
Most Pine flooring will look either white, yellow, or rustic. It is not easy to distinguish one from the other, except rustic. Unless they are fresh cut. Here is a pic of heart pine that is as close as I can get to your floor. This floor is 1/4 and rift sawn. Sorry for the size of the pic. I don't know what happened.
I LOVE THE SMELL OF SAWDUST IN THE MORNING!
woodman58 is offline   Reply With Quote
Old 04-21-2013, 09:41 AM   #3
Hi thanks for the reply. That definitely looks like it, color an all. So is that just coated with poly?
Old 04-21-2013, 08:26 PM   #4
woodman58's Avatar
Do a search for vertical grain heart pine flooring. You will find many floors to choose from. If you are going to install the new floor with the old I would put a header board where the two floors will meet. If you try to lace the old with the new it will be imposible to draw the new tight because of the gaps in the old floor. If you have the floor installed by a proffesional he will try to match the finish on the existing floor.
Tags
pine
Pine shelves maljeff Carpentry 4 03-18-2013 04:24 PM
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 02:01 PM
hardwood over old pine floors nwhitehurst Flooring 4 03-13-2011 11:06 PM
Oak floor over pine? bhry Flooring 1 11-30-2010 10:30 PM
White Pine Hard-Wood floors? MrShadetree0222 Flooring 9 11-04-2008 09:24 AM
