PET Stains Gone Through To Plywood - Flooring - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 05:32 PM   #1
PET stains gone through to plywood
Finally removed the builder's grade carpet and padding to reveal terrible pet stains seeped through to the ply wood (2nd floor of 3 for 94 townhouse) Can I safely use the Zinner 123-primer water base on hand to safely "cover" the odor" that has been there. The wood trim used to tack the carpet down was even rotted through at certain areas. This remains really a do it all 3rd bedroom and really the cat litter room--so aesthetically speaking no one will be the wiser. Finally can I put any type of wood flooring on this floor or keep to new carpeting?
Appreciate any feedback
Teresa
tennisdoc1 is offline   Reply With Quote
Old 08-09-2012, 07:11 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 340
If the wood isn't damaged too much, sealing will work. But not with Zinsser's Bulls Eye 1-2-3. B-I-NŽ SHELLAC-BASE PRIMER would be the one. http://www.rustoleum.com/CBGProduct.asp?pid=216
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
tennisdoc1 (08-10-2012)
Old 08-09-2012, 07:41 PM   #3
Thanks Jaz, was hoping not to buy anything else--but I checked out the descript--and hopefully it will do the trick.
Teresa
Old 08-10-2012, 02:29 PM   #4
Rewards Points: 264
The solvent based seems to be a lot stronger and like it would mask smells better. We have however used the waterbased killz for clients who specifically requested it and it did the trick.
Awoodfloorguy is offline   Reply With Quote
The Following User Says Thank You to Awoodfloorguy For This Useful Post:
Old 08-10-2012, 02:39 PM   #5
I used the BIN product and misjudged the real amount needed for the 10x12 but 2 quarts covered what I really needed to cover. Other than the BIN product smell wafting through--urine smell seems very faint so far.
Teresa
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-24-2011 11:58 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
