Perimeter Expansion Gap For Subfloor Needed? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-04-2010, 04:33 PM   #1
Question
Perimeter expansion gap for subfloor needed?
Hi,
As my kitchen subfloor (T&G planks, 3/4 inch) had water damage and other general damage, I decided to replace it. I cut it flush with the wall, and will soon be ready to replace it with plywood (T&G, 3/4 inch) plywood. I kept reading that you always need 1/4 " expansion gap around perimeter and 1/8" in-field.
A) Do I need that gap in the perimeter for subfloor?
B) If yes, then pbly do I need support underneath subfloor along the wall (which are perpendicular to joists)?
My thinking right now is to have support under wall edge, leave 1/4" gap then fill it with caulk or other flexible materials.
Then I plan 1/2" plywood (staggered) also with 1/4 inch gap on perimeter
Then radiant floor then ditra then tile...
I hope you guys can help,
Thanks in advance
Oakmonter is offline   Reply With Quote
Old 10-04-2010, 10:03 PM   #2
jlhaslip's Avatar
Rewards Points: 2,206
I would block the edges as you discuss.
No gap with plywood. Cut it to within an eighth. Glued and screwed.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Is a Hot Water Expansion Tank required Needagameplan Plumbing 9 04-27-2010 03:09 PM
Bathroom perimeter joints: just leave 1/4" open on perimeter if wood trim will hide? lazzlazz Tiling, ceramics, marble 0 04-23-2010 03:01 PM
Laminate Expansion Gap & Room Size BataviaJim Flooring 7 03-25-2009 06:50 PM
Expansion Joints mpt1123@adelphia.net Flooring 4 03-09-2006 05:44 AM
expansion joint farrington135 Building & Construction 1 01-27-2006 10:02 PM
