* PERGO Vs SHAW LAMINATE FLOOR - LOWER LEVEL FAMILY ROOM !!!! - Flooring - DIY Chatroom Home Improvement Forum
Old 05-14-2011, 02:47 PM   #1
* Buy PERGO vs SHAW LAMINATE FLOOR - LOWER LEVEL FAMILY ROOM ???????
will be replacing my carpeting in the lower level, 4 ft below ground, with laminate flooring.... not sure which brand to buy?
may be between SHAW Laminate we saw at Menards, rand style is ML 239, Natural Appeal, Sierra Oak, ,, which states to have a 40 YR Limited Warranty...........not sure what that means.
2nd brand,,, is Pergo, Style: Pergo/Presto, Bridgport Red Oak,,, saw at Home Depot......25 Yr residential warranty,,, not sure what that means....
I know we'll need to lay down a proper foam underlayment.
ANY OPINIONS OF PROS & CONS OF EITHER BRANDS?
Thanks much.
sfagtjt is offline   Reply With Quote
Old 05-14-2011, 10:55 PM   #2
Rewards Points: 212
just get the cheaper one. If the floor does not have an underpad be sure to lay underlayment. 40 year warranty... who cares you will probably cange the floor 2 more times in that time span or will have moved
bluebird5 is offline   Reply With Quote
Old 05-15-2011, 12:09 PM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I've sold both in the past and do a lot more with Shaw than I ever did with Pergo. Pergo quality has suffered in recent years as well. Shaw has always stood behind their product exceptionally well in my experience.
Darkling Designs
poppameth is offline   Reply With Quote
Laminate & hardwood in the same room, good or bad idea?? phatjoe Flooring 10 05-14-2011 09:57 PM
Any Opinions on Shaw Laminate eerrpp Flooring 6 03-26-2011 01:08 PM
reviews pergo elegant expression laminate asterias Flooring 0 11-17-2010 02:02 PM
Wanted: Pergo Paradigm laminate flooring PG 7005 Ivory Sandstone ridgebluff General DIY Discussions 6 05-30-2008 03:03 PM
Laminate Floor in Sunken Room w/ Tile on Edge z0s01 Flooring 1 02-20-2007 10:44 PM
