Old 03-15-2009, 03:18 AM   #1
Question pergo prestige vs pergo accolade
I was wondering what the difference was between the pergo accolade and the pergo prestige with the underlayment attached-what is the difference?
sunshinejoy@cha is offline   Reply With Quote
Old 03-15-2009, 06:06 PM   #2
Super Moderator
Floorwizard's Avatar
One is sold at the big box stores and the other is not.
I wish I knew more about the big box products to help.
Time to ride again!
Floorwizard is offline   Reply With Quote
More On This Topic
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
Hard Wood Floor Care
Hard Wood Floor Care by Expert Village
Caring for hard wood floors is something people debate on a lot. First of all, you want to sweep a lot. You want to use a broom that has bristles that are frayed at the end so that way you don’t have to mess with scratching the ground, scratching... Read More »
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
Hardwood is a durable, low maintenance choice for flooring, but even the highest quality wood floors can end up with scratches, dents and dull finishes. Daily wear and tear is inevitable, but you can prolong the new look of your floors by taking a few... Read More »
Most woods are categorized as either hardwood or softwood, depending on their density and weight. Softwoods grow faster than hardwoods and are softer, easier to work and cheaper, making them a versatile choice for many carpentry projects. Hardwoods are... Read More »
Cutting Pergo Prestige Foam Backed Chemist1961 Flooring 0 12-23-2008 08:02 PM
Sealing Pergo CD08 Flooring 13 09-16-2008 08:49 PM
Any experience with Pergo Prestige laminate? danidisney Flooring 1 07-21-2008 07:01 PM
Pergo Presto - Snap, Crackle, Pop NickiB1109 Flooring 2 11-07-2007 12:34 AM
Pergo Presto diyfred Flooring 12 05-06-2006 11:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
