Old 05-07-2011, 12:04 PM   #1
Pergo Laminate Flooring Problem
I recently had Pergo plank flooring installed throughout the house. About two to three weeks after the professional install (an experienced private contractor), the plank flooring in the hallway, right at the bedroom door threshhold began to rise. There are three 5 inch planks involved.the two outside rising at small angles and the third in the center flat. The total rise is about 1/4 inch. When weight is placed on it it will lie flat. I & the contractor pulled the baseboards to check spacing. There is more than adequate space at the walls. We removed all of the furniture from the bedroom to fully unweight the floor and using a pry bar attemted to move the floor inside the bedroom (this floor is level and the pergo flat from the threshhold to the far wall). No movement.
He says he has not seen this problem before. usually a bubble, even a small one indicates there is not space for the floor to float. Based on the inspection of the gaps under the baseboards it should float - but it does not?
Possible solutions suggested by him in the order of his preference are 1. remove the flooring to the place where it is binding and replace the boards that are making the rise (theory being there is a problem with one or more boards connection joints), 2. top nail the rise down - which he states may work for the life of the floor or for a brief period only (no way to know for sure), or put in a transition at the door to give the risng floor room to move (my wife really hates this idea).
I am at a loss. It seems the floor should float one way or the other, yet it is fine on either side of the three boards. Would greatly appreciate any ideas to solve this problem. Help!
whosallen is offline   Reply With Quote
Old 05-07-2011, 12:33 PM   #2
woodman58's Avatar
Was the laminate acclimated? Some need to be, some don't. When laminate was first introduced into the US all doorways less than 3 feet had to have a transition. Now then don't call for them. Did he check for moisture with a moisture meter? It almost sounds like a moisture problem. It sounds like he is willing to fix the problem. But, don't let him put any nails thru the floor. This will lock it in place and you will end up with more problems.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
whosallen (05-07-2011)
Old 05-07-2011, 02:01 PM   #3
Yes the flooring was in the house in the rooms for 4 days before the install. Yes the moisture on the floor was checked and found to be low. I do not like the nail idea either (not his favorite choice for that matter) as it seems to defeat the notion of a floating floor. thanks for the input.
Old 07-23-2012, 11:54 AM   #4
A t mold is required in any doorway less than 48". This is manufacturer spec. Customers don't like them, but they are required.
Ed Griffin
Certified Hardwood and Laminate installer
Ed Griffin is offline   Reply With Quote
Old 07-24-2012, 08:22 PM   #5
Do not face nail and permently attach a floating floor.
Iflooru is offline   Reply With Quote
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 09:00 AM
Which direction to install laminate flooring - Floorplan attached oONightFireOo Flooring 8 01-31-2010 04:01 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 11:44 AM
DESPERATELY Need Pergo Paradigm Grey Slate laminate flooring Mariodii Flooring 1 07-01-2008 09:26 AM
Laminate timber flooring over exsisting slate scott10 Flooring 6 06-20-2008 05:04 PM
