Pergo Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 10-03-2012, 05:34 PM   #1
pergo flooring
I had a water leak which made my pergo floors chip away, they are the old ones that had to be glued together even though they are snapped together. There are two places that are chipped up. Tried to replace the wood flooring it loks terrible
Debbie B is offline   Reply With Quote
Old 10-03-2012, 06:52 PM   #2
and the question is?
Old 10-03-2012, 07:11 PM   #3
Rewards Points: 14,014
Ok, so now it all need to come out and be redone.
Only time it was suggested to be glued was if it was laid over a slab.
Old 10-03-2012, 07:29 PM   #4
the early pergo had to be glued because it didnt snap together. i was planning on putting the laminate i took out of the kitchen and hallway in the basement but it was glued and had to be destroyed to get it up. there were extra pieces in the basement and they just slide together and don't lock. home depot used to rent the clamping kit you needed to do pergo floors back then.
Old 10-04-2012, 11:22 PM   #5
Looking to put laminate flooring in my hallway, livingroom, L shaped hallway and foyer (that has parquet in it now) Does anyone had a suggestion? THANKS.
DMW004 is offline   Reply With Quote
Old 10-08-2012, 06:28 AM   #6
Interior design firms
Well, water is an old enemy of the pergo flooring.You need to replace your flooring completely.
langand is offline   Reply With Quote
Old 10-08-2012, 10:55 AM   #7
Rewards Points: 5,988
Yes don't do it. Look at refinishing the parquet or engineered flooring or real hardwood.
Old 10-08-2012, 12:32 PM   #8
Too Short? Cut it Again!
Or bamboo or cork.
Point is, people are on to laminate and it is what it is. It was once a step up from vinyl and it was supposed to outlast hardwood, save forests and even slice and toast bread. Pergo, to start, came with outrageous warranties but there was so much fine print most people got screwed. It has not worked out well.
It screams cheap and not just budget conciousness.
Pergo Laminate Flooring Problem whosallen Flooring 4 07-24-2012 07:22 PM
Best tool cutter for Pergo laminate flooring that is already laid down? Sephora Flooring 12 10-24-2011 08:28 AM
Sub Flooring for Pergo Floor. CJMEDINA Flooring 3 08-15-2010 03:15 PM
pergo flooring avacarr Flooring 2 12-10-2008 04:17 PM
Wanted: Pergo Paradigm laminate flooring PG 7005 Ivory Sandstone ridgebluff General DIY Discussions 6 05-30-2008 03:03 PM
