Pergo Floating Floor On Existing Hardwood ? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 07:55 AM   #1
Pergo floating floor on existing hardwood ?
Hello every one I am new here My question is I would like to install a pergo floor that already has the padding installed on the underside i guess this is considered a floating floor there is a pine hardwood floor down already that is in really bad shape . should the new floor be installed in the same direction as the old one or can i change the direction if i desire .
ants1929 is offline   Reply With Quote
Old 02-01-2011, 08:33 AM   #2
woodman58's Avatar
You should alway change directions when putting wood or laminate over and existing floor.
woodman58 is offline   Reply With Quote
Old 02-01-2011, 09:13 AM   #3
Thanks for the reply and the advice is there a reason why you should change direction with a new floor thanks
Old 02-01-2011, 10:12 AM   #4
As long as the surface is flat and stable you can put your flooring down in whichever direction is aesthetically pleasing. The flooring media is not more directionally stable one way than another aside from the seams. If your floor is so uneven that the seams are compromised one way and not the other you should level your subfloor first in either case. Laminate flooring is not adding any strength to your subfloor by installing it as it is not a suitable material to derive strength and not mechanically fastened. It is simply a veneer and can be put down however you like.
FlooringDude is offline   Reply With Quote
Old 02-01-2011, 02:54 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 388
Why not have the old floor refinished? Seems to me that installing a plastic laminate over real wood is going in the wrong direction.
Jaz
Can I install hardwood flooring over an existing hardwood floor? Max1119 Flooring 12 05-31-2012 11:17 AM
Hardwood floors installed over 1/2" and 5/8" subfloor interplexr Flooring 1 01-25-2009 01:00 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 11:16 AM
Pattern of hardwood to existing hardwood floors garnet4ever Flooring 4 07-31-2007 03:34 PM
Adding Pergo to Existing floor jtyates533 Flooring 7 01-11-2007 01:55 PM
