Pergo - Flooring - DIY Chatroom Home Improvement Forum
Old 01-13-2004, 03:25 PM   #1
RogerB's Avatar
Question
Pergo
I want to install pergo in my Living Room. Its on a hard wood subfloor.
Should I use the snap lock kind or the glue kind and which one looks the best once its down?
Installation tips would be great :confused:
RogerB is offline   Reply With Quote
Old 01-13-2004, 04:02 PM   #2
Floorwizard's Avatar
Both look the same when down Roger. You want to pick out the Pergo first before deciding weather or not to glue it.
Some Pergo you cannot glue, although I would recommend it if the manufacturer says it's o.k. It is cheap insurance. But it will make plank replacement that much harder, but the seam integrity with moisture is better.
Floorwizard is offline   Reply With Quote
Old 01-15-2004, 04:42 PM   #3
RogerB's Avatar
Thanks Florcraft :D
So, can you glue some of the snap lock kind too?
Old 01-15-2004, 04:59 PM   #4
Some brands you can, Pergo accolaid you cannot.
Old 01-16-2004, 02:42 PM   #5
RogerB's Avatar
Is there a brand you recommend besides Pergo?
Old 01-16-2004, 03:57 PM   #6
Wilsonart.
www.wilsonart.com
high pressure laminate - great value.
only Pergo Select is high pressure, and it is more expensive
Old 05-01-2004, 12:29 PM   #7
Guest
Guest
Posts: n/a
What kind of flooring does
armstrong have? I'd like the floating kind if possible, and my original floor is not level, does that make a difference?
Old 05-04-2004, 03:43 PM   #8
Floor must be flat and level.
www.Armstrong.com for some lam ideas.
Old 03-07-2005, 01:16 AM   #9
Pergo Signature Is By Far The Best Product On The Market
lowes#1fan is offline   Reply With Quote
Old 03-07-2005, 11:19 AM   #10
Contractor
Pergo makes an installation video, you would be wise to get a copy. Most of the info applies to all floating flooring. Glue togethers are not covered.
It's about $15.00.
Teetorbilt is offline   Reply With Quote
Old 03-09-2005, 04:23 AM   #11
These other guys know more about laminate products than I do and have given good advice. I have a question just to make sure about something. Is your existing hardwood over a wood subfloor?
Jerry T is offline   Reply With Quote
Old 03-13-2005, 11:57 AM   #12
Novice and FLooring
Roger: Being somewhat of a novice, I have experienced both glue and glueless snaplock. I would say the snaplock is much more preferrable. There is less of a chance to make a mistake and have that mistake accentuate as you progress with installation. A small misalignment on one end can be a big misalignment on the other end. I did not have this problem with glueless snap lock.
Jerry
jeraldb is offline   Reply With Quote
Old 08-10-2005, 10:16 AM   #13
Retired N lovin It
Send a message via Yahoo to VetteMan
Pergo from Home Depot is JUNK!!!!!!!
Guys ... Just a quick note .. I installed 800 sq ft of Pergo Presto from Home Depot in my Kitchen and Family Room. It is crap!!!! it looks nice .. but end seams will randomly open up .. you can get your fingernail in the gap and the corners and edges of the ends will chip off . I have about a dozen of these .... a lot of money($2800) for a product that does this. A local flooring guy told me that Home Depot sells a pergo product that is inferior to that which you can buy at a flooring store ...... I dont know about this .. but no way would I use it again ....
VetteMan is offline   Reply With Quote
Old 08-10-2005, 05:44 PM   #14
Somewhat true.
The same type Pergo can be found at a flooring store under another name.
But the higher end stuff is ONLY at the flooring stores. Not at HD.
Pergo water damage replacement Sol Flooring 16 02-23-2012 01:29 PM
Pergo Presto diyfred Flooring 14 10-07-2010 03:52 PM
Adding Pergo to Existing floor jtyates533 Flooring 7 01-11-2007 01:55 PM
Wood stair covering...pergo? DK75 Carpentry 6 11-02-2006 10:51 PM
Bubble in Pergo from spill Chris165 Flooring 5 06-13-2006 09:16 PM
